update or insert blocks with attributes
for example how can i import a layer from a different dwg. with commands only
tbh, I'm not sure you can but you can use the -LAYER command o construct it from scratch.
To import a file there are several ways. If you put your blocks in a common folder and you add that folder to your search path then -INSERT BlockName will work. Alternatively you can specify where to find the file, -INSERT C:\MyBlocks\BlockName
  • Replies 24
  • serdas
    12
  • dbroada
    7
  • nocturne00
    5
  • ReMark
    1
yes correct
thank you
i am giving a try hopefully i will be able to make it
thanks
It only needs patience and the better your understanding of basic AutoCAD commands the better. There are a couple of "gotchas", particularly when the question is asked differently between "live" and a script but in general the script should look identical to how you wouldtype on the command line.
If you have a script, print it out and type it in the commond line, line by line.
If you need a script step through on the command line and write each line on paper (or notepad) noting everything AutoCAD expects as an answer.
I have attached a simple script we create to batch plot some drawings. This has an odity in that I draw a line and imediately erase it. Why? Because usually AutoCAD thinks a print is a change to the drawing and asks if you want to discard changes but sometimes it doesn't. Putting in a line forces the question to be asked. Since I'm discarding all changes I needn't erase the line but never mind.
The resume is just something I now put at the end of all my scripts. Notepad sometimes puts a blank line at the end which AutoCAD interprets as "repeat last command". Resume is a sort of "do nothing" command so it doesn't matter if it gets repeated.
WHICH COMMAND IS RESUME
THANK YOU
resume actually restarts a script that has been stopped early. I just use it to prevent spare lines at the end of a script from repeating the last command.
