Return a sum to an editbox.
Attila The Gel
Hi,
Can some one show me how I can get the below code to work?
I cant seem to return a result of formula to an edit box.
as you can see from the code snip below, when I type a real number in edit box 1 I would like to get the sum of edit box 1 and 154 to edit box 2. and the same with edit box 2 but then minus 154.
(action_tile "eb1"
[indent][indent]"(setq eb1 $value)
(set_tile \"eb2\" (+ eb1 154)") ;NOT WORKING
[/indent]
[/indent](action_tile "eb2"
[indent][indent]"(setq eb2 $value)
(set_tile \"eb1\" (- eb2 154)") ;NOT WORKING
[/indent]
[/indent]
thanks
Edited by Attila The Gel
Solved
edit_box tiles use strings and tile keys should also be strings, not symbols, hence I would suggest:
(action_tile "eb1" "(set_tile \"eb2\" (if (setq eb1 (distof $value)) (rtos (+ eb1 154)) \"N/A\"))")
(action_tile "eb2" "(set_tile \"eb1\" (if (setq eb2 (distof $value)) (rtos (- eb2 154)) \"N/A\"))")
Thx Lee Mac,
thats almost perfect. Just that the result is with precision 0.0000 what do i need to change in order to get a rounded number.
if eb1 = 2000 then eb2 = 2145 and not 2145.0000.
thx again
its nice to know that you still rock here :)!
Read the documentation on the rtos function :thumbsup:
Cheers dude! :beer:
Just read it and problem solved.
I may have some new questions as I'm trying to learn Lisp and DCL until my lisp programming lessons start on 10/10.
