I'm having trouble extruding a profile i have created. Get "Cannot sweep or extrude a self-intersecting curve" error. I have used the overkill command to find any duplicate lines. Any help would be greatly appreciated. Trying to extrude along a straight line.
profile.dwg
Edited by cbsmiley
add more info
Does presspull work?
But I think I would fix this loop.
Also I dimensioned this thing in inches and metric and the dimensions don't make sense to me (not manufacturable).
thank you, i found the lines right after posting the question. Also what do you mean by dimensioned? its is a cornice profile so if it was extruded it would form the finished positive shape; it is to be made by bench running plaster.
If I dimension the profile the lines do not come out to measureable, logical values like 1 inch, instead coming out to something like 1.2345678
