sam_dubya Posted September 5, 2012 Share Posted September 5, 2012 Hello everyone, I am having an issue with my print to PDF. When a drawing is printed to PDF, any notes on the drawing, some of the font comes out grey and is very hard to read. Does anyone have a solution to this? I'm using Autocad 2013. Cheers Sam Quote Link to comment Share on other sites More sharing options...
MSasu Posted September 5, 2012 Share Posted September 5, 2012 If the same drawing is plotted on paper the said issue is present or not? Have you checked the settings from CTB file in use? What do you use to plot to PDF; the built-in feature (DWG to PDF) or a third-part virtual printer? Quote Link to comment Share on other sites More sharing options...
Tiger Posted September 5, 2012 Share Posted September 5, 2012 Do you use a CTB-file when you plot? Check what linewieght and screening the colors are set to in the CTB-file. Are the notes/fonts set to a color outside of the standard colors? Such as 256,256,256? Quote Link to comment Share on other sites More sharing options...
