Explode nested blocks only
Cazza
Do anyone in this Forum can recommend me a great book to learn how to create my own Visual lisp Routines? I have seen a lot of books on the internet and Amazon but I would like to get a good one from any of you that already knows the programming language. I have a low-level skill as a programmer but I have read a lot and I understand a lot of things now.
Thank you in advance.
Try Kindle some good books and very cheap can copy code from book that's important. I downloaded 4
  • 2 months later...
On 20/07/2016 at 17:32, MURAl_KMD said:
hi Lee Mac
Thanks to you for all codes , which helps me a lot
(repeat (setq idx (sslength sel))
(LM:burstnested (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
The above code modified in NestedBurstV1-0.lsp of Lee Mac
(LM:ApplytoBlockObjects
(vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
(vla-get-effectivename (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
'LM:burstnested
This works for me so far ,
Hi, Sorry for digging up this old thread. Currently in need to burst attribute blocks or nested attributes blocks to a normal block with all field input intact. is there a way to do this?
  • 10 months later...
If it isnt a big problem i would someone to modify the lisp so it can explode nusted mtexts to texts without exploding the primary block.
  • 4 years later...
Hi all,
is it possible to tackle removing all nested blocks the other way around? how can i ask autocad to explode all blocks Only if they embed at least one more blocks inside them?
i want my file to only have normal blocks and not any nested block inside it.
