How do I exaggerate the vertical scale in a profile drawing
I have drawn my subsurface profile at true scale in Model space. I now want to create a layout with a vertical scale of for instance 1"=5 ft and a horizontal scale of 1"= 50 ft, or a 1:10 exaggeration. I have spent countless hours trying to figure this out with maunals and on-line. It seems like such an easy thing to do but I can't seem to figure it out...
Thanks for your help.
You can draw everything with a 10:1 exaggeration. So hold the horizontal scale at 1:1 (draw true scale) and for vertical objects apply the 10:1 scaling. So a 1' diameter pipe is drawn 1' wide and 10' high (an ellipse).
Sometimes it may be useful to draw some objects at 1:1 scale; then make a block of it, then insert the block with a 10:1 y to x exaggeration. You can explode this block if you need to, although curves will be reduced to lots of short segments.
Thanks for the reply, and as the administrator pointed out, I did not mentu ion my version of autocad. I am using Auto cad LT, 2006. Is this still posible?
Yes still possible with LT. All just basic drawing commands to create profile information, then "block" to create block of any linework to be converted from 1:1 to an exaggerated scale, then "insert" and possibly "explode".
Guest Alan Cullen
sjr,
The easiest way is to create a block WBLOCK and insert it back into the drawing with "x" factor = 1 and "y" factor = 10. It will screw any text you have in the block, so do your profile first, block it, bring it back in, then enhance it.....
....all as CarlB suggested... :)
Thank you so much Alan and CarlB! That worked like a charm.
sjr
  • 7 years later...
Block method is the way to go ... thanks for the great idea. Before I was going station by station scaling my elevations by 10 or 20 X. The block method is so much quicker and easier. Thanks again!
