hfs Posted August 31, 2012 Author Posted August 31, 2012 Yeah Thanks guys for your time. I will let you know how things turn out... Quote
JD Mather Posted August 31, 2012 Posted August 31, 2012 You didn't indicate desired Thickness which side (or midplane) for the thickness. See attached (use ACISIN to import back into AutoCAD). oops, never mind - the file is too large (776kb) to attach here. I used Autodesk Inventor to do the job. Hmm, for some reason I can't even upload a picture today. Well, that was too much work to get this image attached. Seems like the site is broken. Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 JD Mather said: You didn't indicate desired Thickness which side (or midplane) for the thickness.See attached (use ACISIN to import back into AutoCAD). oops, never mind - the file is too large (776kb) to attach here. I used Autodesk Inventor to do the job. Hmm, for some reason I can't even upload a picture today. [ATTACH=CONFIG]36875[/ATTACH] Well, that was too much work to get this image attached. Seems like the site is broken. Thanks! I don't have INVENTOR in my system. I will try to get it! Quote
ReMark Posted August 31, 2012 Posted August 31, 2012 We'll assume you mean "purchase" unless you are a student of course. They can download Inventor as well as many other programs from the AutoDesk website for free. Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 ReMark said: We'll assume you mean "purchase" unless you are a student of course. They can download Inventor as well as many other programs from the AutoDesk website for free. Yes I am a student. I will try to download a student version for free or ask my supervisor to get a license. Thanks guys. you were a great help! Quote
ReMark Posted August 31, 2012 Posted August 31, 2012 Good luck with your endeavor. When you finish come back and post an image. Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 ReMark said: Good luck with your endeavor. When you finish come back and post an image. Thanks! I will... hopefully soon Quote
JD Mather Posted August 31, 2012 Posted August 31, 2012 hfs said: Yes I am a student. I will try to download a student version for free or ask my supervisor to get a license. Students can get Inventor for free from http://www.autodesk.com but per the license agreement you cannot use it for commercial purposes, only for student learing. If you only need it for this one job - install it as 30-day trial. After you finish you could activate the 3-yr student license if desired. This document explains what I did http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 JD Mather said: Students can get Inventor for free from http://www.autodesk.com but per the license agreement you cannot use it for commercial purposes, only for student learing.If you only need it for this one job - install it as 30-day trial. After you finish you could activate the 3-yr student license if desired. This document explains what I did http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf Thanks a lot for the document. I am using it for my master thesis (studying purpose). My Regards,,, Quote
Patrick Hughes Posted August 31, 2012 Posted August 31, 2012 ReMark said: Please answer my questions in post #13. This is funny why?? I think he was laughing at your coffee comment. Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 Patrick Hughes said: I think he was laughing at your coffee comment. Correct! Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 Yesssss! AutoCAD can always do it! 1-3D Modeling workspace --> Mesh--> Convert to Surface 2-3D Modeling workspace --> Surface --> Offset right click -->Solid Done! Quote
Guest DONTBEADICKUCADNERD Posted August 31, 2012 Posted August 31, 2012 Try this: 1. Do a UNION to make all the surfaces into one, 2. THICKEN worky or no? Quote
hfs Posted August 31, 2012 Author Posted August 31, 2012 DONTBEADICKUCADNERD said: Try this: 1. Do a UNION to make all the surfaces into one, 2. THICKEN worky or no? Did not work. Maybe it can work but after executing "convert to surface" command. Thanks for your add! Quote
JD Mather Posted September 1, 2012 Posted September 1, 2012 hfs said: Thanks a lot for the document. I am using it for my master thesis (studying purpose). My Regards,,, Keep in mind that they added the Repair Environment that is supposed to replace the older Construction Environment. If you would like to collaborate on a future AU paper or AUGI Wold article - let me know. Quote
