Kari605 Posted August 28, 2012 Posted August 28, 2012 This only happens from time to time. I have a sheet set up with multiple viewports. I double click in one viewport, type LAYER, and the layer dialog appears but my viewport has changed. Anyone else have this problem and more importantly have a solution? Thanks. Quote
SLW210 Posted August 29, 2012 Posted August 29, 2012 What changes? Can you post some images or even better the .dwg? Quote
Bennymac777 Posted August 29, 2012 Posted August 29, 2012 click in the viewpoint and use the command ucsfollow and set the variable to 0. Try that. Quote
