First routine again prompts to select the lines.Can the same thing be done in background I mean without prompting.
(defun c:drawLine (p1 p2 p3 p4)
(Command "._line" p1  p2 "")    ;; <=== p1,p2,p3 and p4 are points created using polar
(Command "._line" p3  p4 "")
Can I select only first line and do offset .
  • Replies 24
  • avinashg
    13
  • Tharwat
    6
  • Dadgad
    2
  • neophoible
    2
Is any solution available for this.
How about just using entlast right after drawing the LINE? E.g.,
(setq Line2Offset (entlast))
Thanks
Neophoible
and
Tharwat
Here how i solved it.
   (command "._pline")
   (foreach item lst (command item))
   (command "_c")
  (vla-offset (vlax-ename->vla-object Line2Offset) -0.1)
You are very welcome. Glad to help.:)
