Hi,
Recently I've gotten into this type of problem.
Have an ATT "A" that is set. I can change it and it will change. But I also have an ATT "B" which works the same way as the "A".
I've added a MTXT into the block so that both ATT's A and B will work together, meaning they will always be in a dead center - something like text (no matter what the string is, you can Align it Middle Center), using a FIELDS option, and parameter set to VALUE.
It works when placed into the drawing, but need something that once I place the block and want to edit the VALUE, the Fields will update/sync.
I'm asking for some guidance from you guys.
Thank you in advance for the help.
Vee
A and B.dwgFetching info...
Hi ,
If I got your point , Try the updatefield command to update the value .
Unfortunately, even though it says that it updated so and so fields, it does not update them at all.
My settings are set to 31 as for the Fields updating.
