Dimension Text Direction & Position
Dave^
Hi Gents,
Long time no pester!!
I'm looking for a "easier" way of changing specific dimensions to read "right-to-left" and be positioned "below" the dim line.
Due to mvsetup, when rotating my views in my viewports, text on the Y-axis is upside down.
I know there's an way to change properties, i have "(vlax-property-available-p x 'explodable)" in a lisp (which I think I got from here) to change blocks from not being able to be exploded.
I've wasted an hour searching for a solution to a 5min problem... :lol:
Any hints?
Try this Dave:
(defun c:dimupd ( / sel )
   (if (ssget "_:L" '((0 . "DIMENSION")))
           (vlax-for obj
               (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
               (vla-put-dimtxtdirection obj :vlax-true)
               (vla-put-verticaltextposition obj acunder)
           (vla-delete sel)
(vl-load-com) (princ)
Legend, thanks Lee...
1 virtual Friday pint for you!!!
Oh, by the way...
Part of my hour search earlier was playing Mastermind... o:) So thanks for that too!!
  • 1 year later...
Dear Lee,
From where did you get to know about "vla-put-dimtxtdirection", "vla-put-verticaltextposition" and acunder properties ?
The biggest problem in Visual LISP is that proper listing of all functions along with their explanation and properties are not available anywhere properly.
  • 2 years later...
Great piece of code there Lee Mac, i would like however to it being able to change it back with the same command.
Something like
If (Dimension is normal) {
  - Change view direction to Right-to-Left
  - Change Text pos vert to Below
} else if (Dimension is allready changed) {
  - Change view direction back to Left-to-Right
  - Change Text pos vert back to Above
Would that be possible? (ofcourse it would :P) And how?
Try the following:
           (vlax-for obj
               (vlax-put obj 'dimtxtdirection (~ (vlax-get obj 'dimtxtdirection)))
               (if (= acunder (vla-get-verticaltextposition obj))
                   (vla-put-verticaltextposition obj acabove)
           (vla-delete sel)
  • Thanks 1
  • 3 years later...
Very nice routine Lee, thank you very much for providing it.
  • 1 year later...
Hello,
I'm looking to find a way to align multiple dimension text. The reason is that I'm using the Viewport and all dimension aren't visible. Attached are 2 drawings explaining my problem, to change the position, I manually copied the coordinates in the properties and inserted them in the dimensions I wanted to change.
Is it possible, by using the text position X or Y coordinate, to modify by lisp the other dimensions?
I have started the routine from this forum but I don't know how to make it work. I have no idea how to program lisp.
Can somebody help me please.
Many thank
DimensionAlignManualy.dwg Dimension.dwg DimTextMove.lsp
Not sure but dim hor 2 points, then Base pick 1st dim then pick next pt, next pt all done.
Hello Bigal,
I think your proposal is not what I'm looking for.
When I'm working on the model space I would like to move the dimension text (in red) to the same x position as the visible dimension
Could read the dim string sort on that then edit the order, updating the dimension location,  a doable task, but for me do it right in 1st place.
this is what I'm exactly looking for but I can't get the lisp to work, the DTA command doesn't appear
If you have the lisp is it open code or a FAS ? If open look for C:DTA or something similar that is the function command name after the c :
Edited by BIGAL
Hi Bigal
Here the lisp that I upload, but in Vlx format. And c:DTA is not working
DTA (v1.0).VLX
Edited by francine2013
