EvanZabadah Posted August 23, 2012 Posted August 23, 2012 I looked for the springs in Inventors material list but cant seem to find them. The main spring would not be too bad but the hooks look like it would be time consuming. Didn't know if there was an easier way. Here is a picture or the spring. Thanks for all of you guys time Quote
EvanZabadah Posted August 23, 2012 Author Posted August 23, 2012 I see the coil command but what do you draw to start the coil feature Quote
JD Mather Posted August 23, 2012 Posted August 23, 2012 In the Content Center or Coil a circle (the ends will be a bit more work). When I get a change I will post example. Quote
EvanZabadah Posted August 23, 2012 Author Posted August 23, 2012 Could not find in content center I will look again I spent alittle bit of time trying to coil a circle but had no luck. An example would be very helpful take your time not in super rush. Thanks for your time and help really appreciated. Quote
