MichaelH27 Posted August 22, 2012 Posted August 22, 2012 Is anyone out there familiar with using shapefiles (.shp) and manipulating the data that is contained in the shapefiles? I am new to this mapping world and using GIS files to create functioning Cad dwg's. Spoon feeding would be welcomed! Thanks, Quote
MichaelH27 Posted August 22, 2012 Author Posted August 22, 2012 Map 3d 2013. I am new to the mapping aspect of Cad. I have been around it in the past but never needed to use it. Quote
Emigrato Posted August 23, 2012 Posted August 23, 2012 MichaelH27 said: manipulating the data that is contained in the shapefiles? Well, if you only wanna see the graphic content of a shapefile, with its Gis attributes, type in _MAPIMPORT setting it like this: However, if you must edit the attributes inside, I advise to do it in a Gis opensource, or simply editing the .DBF in Excel (without adding rows). Quote
Murph_map Posted August 23, 2012 Posted August 23, 2012 MichaelH27 said: Is anyone out there familiar with using shapefiles (.shp) and manipulating the data that is contained in the shapefiles? I am new to this mapping world and using GIS files to create functioning Cad dwg's. Spoon feeding would be welcomed! Thanks, I don't have a spoon will a spoork be ok? When you get stuck or confused ask away someone will provide some assistance. Quote
nargothrond Posted September 13, 2012 Posted September 13, 2012 Emigrato, How are you??? Can u explain better how to i edit in excel?? My GPS give me lines i cannot offset, if you want, i can attach my shp files. Tks in Advance! Ps: Sorry about my poor english!! Quote
Emigrato Posted September 14, 2012 Posted September 14, 2012 nargothrond said: How are you??? Fine, thanks. If you'd like to edit the geometry of your survey data, you should simply _MAPIMPORT that shape in Autocad Map, as explained above (see post 23rd Aug 2012 11:37 am). However, if you'd like to edit the inner attributes (textual), use the powerful free Mapwindow_Gis or edit the .DBF in Excel, amigo. Quote
