s3101959 Posted August 22, 2012 Posted August 22, 2012 Hi guys, I have a problem to do oblique dimension with aligning arrows an dimension the isocircle. Does anyone know how to fix this. Cheers Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 yes you are right.... the arrows look really awkward if they are not aligned Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 for sure. The second question would be how can i dimension the isocircle of diameter 2 as usual. Cheers 7C.dwgFetching info... Quote
ReMark Posted August 22, 2012 Posted August 22, 2012 I would create a couple of different dimension styles and appropriate arrowheads to go with them if I found myself having to do these types of drawings on a regular basis. Is this a class assignment? Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 This is not an assignment but i m going through some exercises in a workbook atm because i really want to pick up Autocad. Quote
ReMark Posted August 22, 2012 Posted August 22, 2012 Someone gave me this a long time ago. Maybe it might be of some help. How do I dimension an isometric drawing.docFetching info... Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 Thanks but the tips is to dimension the text instead. What i want to do is to align the arrows. The dimension of isocircles remain an issue as well. Quote
ReMark Posted August 22, 2012 Posted August 22, 2012 You dimension to the center of the isocircle and then call out the diameter You need some isometric arrowheads too don't you? Can't use the default ones as they don't look right. Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 do you know what command should i use? I tried out all of them but none of them seems working for isocircle. Cheers Quote
s3101959 Posted August 22, 2012 Author Posted August 22, 2012 do you know which command is the most appropriate to use for isocircle dimensioning cuz normal dimrad just doesnt work. cheers Quote
rkent Posted August 22, 2012 Posted August 22, 2012 s3101959 said: do you know which command is the most appropriate to use for isocircle dimensioning cuz normal dimrad just doesnt work. cheers Insert the attached drawing into your drawing, use the various styles and follow the instructions to oblique the dims. ISO-DIMensions 2007.dwgFetching info... Quote
