Hello all
I have a lisp routine which will load Layer states and I have assigned it's command to a button - each layer state is assigned to a unique name and a button is created for it - The lisp routine loads a specific .las file into the drawing. For that, I have created a folder with all *.las files stored in it.
The problem is that when I click on a button to turn on a layer state, it will apply the layer state to all viewports. How can I apply a layer state to only one viewport and not affect all viewports in all tabs? below is what I have
(DEFUN C:d105 () (command "Layer" "A" "I" "J:/AutoCAD 2010/Lman/Development/105.las" "R" "105" "" "" ""))
Thank you for helping
Edited by ADSK2007
Are you inside or outside the viewport when you run the command.
Hi BIGAL
I use this line of code when I am inside the viewport - However, I found a way to rectify this - I wrote a Script using VPLAYER command. I turned layers ON and Some Off, then Tested the script to make sure it works fine. I then loaded the script with a lisp code and assigned it to a button. It works like a charm. NOTE: This routine works inside Viewport only and doesn't work in Model space
Regards
Adsk2007
You can also use the layerstate-restore function in lisp. No need to have the VP set to current, just send the VP's ename to that function - you need not even be on the tab on which the VP is.
