bpdav1 Posted August 13, 2012 Posted August 13, 2012 (edited) I'm trying to draw a line with a set length and angle through autolisp, but relative coordinates don't seem to work. If I type (command "line" point1 "3860<-170" "") it draws the line starting at the given point and finishes where it would if point1 = 0,0. Does anyone know how to fix this? I want to draw a line from a set point, with a given length and angle, without having to workout the absolute coordinates of the end point. edit: sorry I eventually found the answer myself, I simply add an "@" to make autocad use the coordinates as relative. Hope this helps someone else! Edited August 15, 2012 by bpdav1 Quote
MSasu Posted August 13, 2012 Posted August 13, 2012 By adding "@" should work, but is better to look to POLAR function instead. Also, take care to avoid interference with current auto OSNAP and conflicts with a localized version of AutoCAD/redefined commands. (command "_.LINE" "_non" point1 "_non" (polar point1 (* (/ -170.0 180.0) pi) 3860.0) "") 1 Quote
MSasu Posted August 13, 2012 Posted August 13, 2012 It enable the None OSNAP mode for next input - this overrides any auto OSNAP mode(s), so doesn't interfere with your drawing process. A better solution is to add the entities directly on database using ENMAKE function instead of using COMMAND; but I suggest you to let this for later when will gain more experience in AutoLISP programming. Quote
MSasu Posted August 13, 2012 Posted August 13, 2012 To understand exactly how auto OSNAP influence the drawing process from AutoLISP, start a new drawing, make sure that Endpoint OSNAP mode is activated and run the two routines below (paste the code on prompter and call TEST1, respectively TEST2 commands). There should be two circles - the smaller one was supposed to be in 3, 3; second is located correctly (5, 5). (defun c:test1() (command "_.LINE" "_non" '(0.0 0.0) "_non" '(50.0 50.0) "") (command "_.ZOOM" "_E") (command "_.CIRCLE" '(3.0 3.0) 3.0) (princ) ) (defun c:test2() (command "_.LINE" "_non" '(0.0 0.0) "_non" '(50.0 50.0) "") (command "_.ZOOM" "_E") (command "_.CIRCLE" "_non" '(5.0 5.0) 5.0) (princ) ) Quote
fuccaro Posted August 14, 2012 Posted August 14, 2012 When drawing something on the screen using the COMMAND function, a possible approach could be: save the current Osnap settings, disable Osnaps, draw your objects and restore the saved Osnap. Like this: (setq Old (getvar "osmode")) (setvar "osmode" 0) (command....) ....... ....... (setvar "osmode" Old) To go a step further: if the Lisp crashes, the saved Osnap is not restored. That's a good reason to write an error handling for your Lisp. Quote
