Lau Posted August 8, 2012 Posted August 8, 2012 How can I change the settings, so that only one object will be selected at a time --> selected objects will be deleted from the selection, picking another object without pressing the 'shift' button? Understandable? Quote
RobDraw Posted August 8, 2012 Posted August 8, 2012 People usually ask how to do the opposite. Change PICKADD to "0". Quote
Dadgad Posted August 8, 2012 Posted August 8, 2012 Welcome to the forum. If you look at the image you will see how to do that. Easier still like RobDraw said. Quote
JPlanera Posted August 8, 2012 Posted August 8, 2012 What are you doing that requires this type of selection?? Are you trying to remove one object at a time from a selection "set", or are you only wanting one object selected at a time??? Quote
Dadgad Posted August 8, 2012 Posted August 8, 2012 Does sound strange, eh? Looking for the REMOVE option during selection perhaps? Quote
Lau Posted August 8, 2012 Author Posted August 8, 2012 Thanx thanx thanx it was the 'pickadd=0' It's just that I'm used to that setting and I couldn't find how to change it in the AutoCAD2013. So I've been moving objects wich I didn't want to move all the time because they maintained selected! Quote
rkent Posted August 8, 2012 Posted August 8, 2012 Thanx thanx thanx it was the 'pickadd=0'It's just that I'm used to that setting and I couldn't find how to change it in the AutoCAD2013. So I've been moving objects wich I didn't want to move all the time because they maintained selected! Set pickadd to 1, it comes set to 2 by default which means that they stay selected until you hit cancel once or twice, can't remember. Quote
RobDraw Posted August 9, 2012 Posted August 9, 2012 Set pickadd to 1, it comes set to 2 by default which means that they stay selected until you hit cancel once or twice, can't remember. Brilliant! Quote
