nicolas Posted August 6, 2012 Posted August 6, 2012 Hi, I have use the Note Text (ISO) to create a new text styles with new text height 2 mm. I have also replace the text style used in the dimension styles with the new one. As to dimension, everything has been changed. As to the text, the change is not applied. I have also drawn a new page border that is listed. However I can't apply it to the current sheet. I have the following error: The active sheet already has a drawing border. Delete the existing drawing border before inserting a new one.Right Clicking the new drawing border, I have the delete option but no such option for the "Default Border". Your help is greatly needed. Thanks. Quote
JD Mather Posted August 6, 2012 Posted August 6, 2012 In the browser you will see a node for the existing border (and views and title block and anything else that you have on your sheet). Right click on this and Delete, not in the Drawing Resources. Quote
nicolas Posted August 11, 2012 Author Posted August 11, 2012 Thanks. I have been able to delete the existing border and replace it with the newly created one. This is great as I no more have to export to Autocad to do set the pagesetups. Quote
JD Mather Posted August 12, 2012 Posted August 12, 2012 Save this as a Template if you will need it in the future. Quote
