AstroNout Posted July 31, 2012 Posted July 31, 2012 Hi guys, I've got a set of suvey points, among a couple of height points. These are displayed by block-pointstyles in combination with a height label in another layer. De client wishes to get them into seperate layers. Is there a way to explode the points into blocks and text, so they stay into these pre-defined layers? Example: A storm drain is in a block DRAIN, on the layer DRA and the label is in a label on layer THT. So the points are drawn in layer DRA. Exploding the whole shabang finally should get the block DRAIN and a label in THT. Thanks, AstroNout Quote
designerstuart Posted July 31, 2012 Posted July 31, 2012 i don't see why if it's already drawn on the right layers, exploding will upset that? do you know command BURST? it's like EXPLODE but leaves all entities as visible before the block was destroyed. Quote
AstroNout Posted July 31, 2012 Author Posted July 31, 2012 allrighty, that's what i needed! Thanks! Quote
MSasu Posted July 31, 2012 Posted July 31, 2012 One extra comment - the BURST command is part of Express pack, not a built-in one. So, the availability of this pack along your AutoCAD is mandatory. Quote
AstroNout Posted July 31, 2012 Author Posted July 31, 2012 Since it's for use within the University, that won't be a problem! Cheers! Quote
AstroNout Posted July 31, 2012 Author Posted July 31, 2012 However... Now I got another problem. I should insert a block and and point on the place of a survey point. Is that possible? And if so, when you explode the survey to get rid of the figures, the point should stay to be a point, and the other one a block. Yeah I know, stupid, put if that's what the Belgian government wants, we shall provide Quote
designerstuart Posted July 31, 2012 Posted July 31, 2012 not quite sure what you mean..... are you trying to add a POINT at every block's insertion point? Quote
AstroNout Posted July 31, 2012 Author Posted July 31, 2012 Some features like the side of the road, height points,... are specifically measured with a height. These points, being nodes of lines or the insertionpoints blocks, should be marked with a point. I'm guessing the easiest way is to write a script for it? Quote
designerstuart Posted July 31, 2012 Posted July 31, 2012 at all of these survey points you want to automatically insert the same block? Quote
AstroNout Posted July 31, 2012 Author Posted July 31, 2012 Well, it should be a point at the end, so no Block. At the position of a storm drain there should be the symbol of a storm drain AND a point with a certain style A and layer B. For survey points, elements of the side of the road, points should be inserted with style A in layer B. All other survey points are ignored. Quote
Murph_map Posted August 5, 2012 Posted August 5, 2012 SLW210 said: I moved this thread to the Map 3D forum. Sounds more like a Civil3D thread. Quote
Murph_map Posted August 6, 2012 Posted August 6, 2012 SLW210 said: Profile claims MAP 3D... Yea I saw that too. Quote
