.Can anyone Please let me know how add the hatches back in the AutoCAD 2004
When I enter the Hatch command I get the following message.
Command: h
HATCH
Enter a pattern name or [?/Solid/User defined] : *Cancel*
Then the program closest by itself, any help on how to solve this.
Thank you!
Type
(findfile "acad.pat")
= Imperial or
(findfile "acadiso.pat")
= Metric
parenthesis included, on the command line and hit enter. This will give you the path to your Hatch Pattern files.
Have you tried to edit these?
Sounds like your .pat file is messed up.
You might try setting another pattern as default, HPNAME is the system variable.
