P Raja Posted July 24, 2012 Share Posted July 24, 2012 Hi all...i would like to keep a record of non-graphical information's into a drawing. i would like to keep the records of drawing like *Project number *customer name & *Revision number as a non graphical data inside the autocad. i found that we can use "dictadd" to store data's inside a drawing and can retrieve from it at any time... can anyone help me? how can i add a data by using "dictadd" and also advise how can i edit the stored data? (ex. incase i do revision 2, i need to change the revision number value) Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 25, 2012 Share Posted July 25, 2012 Consider using DWGPROPS Command, or even Sheet Set Manager Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 25, 2012 Share Posted July 25, 2012 ... More on Dictionaries and XRecords from AfraLISP: http://www.afralisp.net/autolisp/tutorials/dictionaries-and-xrecords.php Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted July 25, 2012 Share Posted July 25, 2012 ; [DCT] ===================================================================================== ; ; cd:DCT_AddDict - Dodaje slownik / Adds the dictionary ; ; cd:DCT_AddXrecord - Dodaje Xrecord / Adds the Xrecord ; ; cd:DCT_GetDict - Pobiera slownik / Gets a dictionary ; ; cd:DCT_GetDictList - Pobiera liste slownikow / Gets a list of dictionaries ; ; cd:DCT_GetExtDict - Pobiera/Tworzy ExtensionDict. / Gets/Creates an ExtensionDict. ; ; cd:DCT_GetExtDictVLA - Pobiera/Tworzy ExtensionDict. / Gets/Creates an ExtensionDict. ; ; cd:DCT_GetXrecord - Pobiera Xrecord / Gets Xrecord ; ; cd:DCT_RemoveDict - Usuwa slownik / Removes the dictionary ; ; cd:DCT_ReplaceXrecord - Podmienia Xrecord / Replace Xrecord ; ; cd:DCT_SetXrecordVLA - Zmienia Xrecord / Change Xrecord ; ; =========================================================================================== ; ; Dodaje slownik / Adds dictionary ; ; Root [ENAME/nil] - ENAME = slownik "rodzic" / "parent" dictionary ; ; nil = (namedobjdict) jako "rodzic" / (namedobjdict) as "parent" ; ; Name [sTR] - nazwa slownika / name of the dictionary ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_AddDict (namedobjdict) "NAZWA") ; ; =========================================================================================== ; (defun cd:DCT_AddDict (Root Name) (dictadd (if (not Root) (namedobjdict) Root) Name (entmakex (append '((0 . "DICTIONARY")(100 . "AcDbDictionary")))) ) ) ; =========================================================================================== ; ; Dodaje Xrecord / Adds the Xrecord ; ; Root [ENAME/nil] - ENAME = slownik "rodzic" / "parent" dictionary ; ; nil = (namedobjdict) jako "rodzic" / (namedobjdict) as "parent" ; ; XName [sTR] - nazwa xrecord / xrecord name ; ; XData [list] - dane xrecord / xrecord data ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_AddXrecord (cd:DCT_GetDict (namedobjdict) "NAZWA") "NAZWA-SUB1" '((1 . "ABC"))) ; ; =========================================================================================== ; (defun cd:DCT_AddXrecord (Root XName XData) (dictadd (if (not Root) (namedobjdict) Root) XName (entmakex (append '((0 . "XRECORD")(100 . "AcDbXrecord")) XData)) ) ) ; =========================================================================================== ; ; Pobiera slownik / Gets a dictionary ; ; Root [ENAME/nil] - ENAME = slownik "rodzic" / "parent" dictionary ; ; nil = (namedobjdict) jako "rodzic" / (namedobjdict) as "parent" ; ; Name [sTR] - nazwa slownika / name of the dictionary ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_GetDict (namedobjdict) "NAZWA") ; ; =========================================================================================== ; (defun cd:DCT_GetDict (Root Name) (cdr (assoc -1 (dictsearch (if (not Root) (namedobjdict) Root) Name))) ) ; =========================================================================================== ; ; Pobiera liste slownikow "rodzica" / Gets a list of "parent" dictionaries ; ; Root [ENAME] - ENAME = slownik "rodzic" / "parent" dictionary ; ; Code [T/nil] - T = zwraca / returns -> ((<slownik1> . <ENAME1>) ... ) ; ; nil = zwraca / returns -> (<slownik1> <slownik2> ... ) ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T) ; ; =========================================================================================== ; (defun cd:DCT_GetDictList (Root Code / dt tmp res) (if Root (if Code (progn (setq dt (entget Root)) (while (setq dt (member (setq tmp (assoc 3 dt)) dt)) (setq res (cons (cons (cdr tmp) (cdadr dt)) res) dt (cdr dt) ) ) (setq res (reverse res)) ) (setq res (cd:DXF_massoc 3 (entget Root))) ) ) res ) ; =========================================================================================== ; ; Pobiera/Tworzy ExtensionDictionary obiektu / Gets/Creates an ExtensionDictionary of object ; ; Obj [ENAME/VLA-Object] - obiekt VLA lub entycja / VLA-Object or entity name ; ; Flag [T/nil] - T = tworzy / creates ; ; nil = pobiera jesli istnieje / gets if exist ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_GetExtDictVLA (car (entsel)) T) ; ; =========================================================================================== ; (defun cd:DCT_GetExtDictVLA (Obj Flag / res) (if (= (type Obj) (quote ENAME)) (setq Obj (vlax-ename->vla-object Obj)) ) (if (setq res (if (= :vlax-true (vla-get-HasExtensionDictionary Obj)) (vla-GetExtensionDictionary Obj) (if Flag (vla-GetExtensionDictionary Obj)) ) ) (vlax-vla-object->ename res) ) ) ; =========================================================================================== ; ; Pobiera/Tworzy ExtensionDictionary obiektu / Gets/Creates an ExtensionDictionary of object ; ; Ename [ENAME] - nazwa entycji / entity name ; ; Flag [T/nil] - T = tworzy / creates ; ; nil = pobiera jesli istnieje / gets if exist ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_GetExtDict (car (entsel)) T) ; ; =========================================================================================== ; (defun cd:DCT_GetExtDict (Ename Flag / res he ta) (if (and (= (type Ename) (quote ENAME)) (setq dt (entget Ename)) ) (if (not (setq res (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") dt))))) (if Flag (progn (setq res (entmakex (append '((0 . "DICTIONARY") (100 . "AcDbDictionary")))) he (reverse (member (assoc 5 dt) (reverse dt))) ta (cdr (member (assoc 5 dt) dt)) ) (entmod (append he (list '(102 . "{ACAD_XDICTIONARY") (cons 360 res) '(102 . "}") ) ta ) ) ) ) ) ) res ) ; =========================================================================================== ; ; Pobiera Xrecord / Gets Xrecord ; ; Ename [ENAME] - nazwa entycji / entity name ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_GetXrecord (cdar (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T))) ; ; =========================================================================================== ; (defun cd:DCT_GetXRecord (Ename / dt) (cdr (member (assoc 280 (setq dt (entget Ename))) dt)) ) ; =========================================================================================== ; ; Usuwa slownik / Removes the dictionary ; ; Root [ENAME/nil] - ENAME = slownik "rodzic" / "parent" dictionary ; ; nil = (namedobjdict) jako "rodzic" / (namedobjdict) as "parent" ; ; Name [sTR] - nazwa slownika / name of the dictionary ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_RemoveDict (namedobjdict) "NAZWA") ; ; =========================================================================================== ; (defun cd:DCT_RemoveDict (Root Name) (dictremove (if (not Root) (namedobjdict) Root) Name) ) ; =========================================================================================== ; ; Podmienia Xrecord / Replace Xrecord ; ; Ename [ENAME] - nazwa entycji xrecord / entity name xrecord ; ; Data [list] - lista par kropkowych / list of dotted pairs ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_ReplaceXrecord ; ; (cdar (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T)) ; ; (list (cons 1 "NEW") (cons 341 (car (entsel))))) ; ; =========================================================================================== ; (defun cd:DCT_ReplaceXrecord (Ename Data / en root name) (setq root (cdr (assoc 330 (entget Ename))) name (cdr (assoc Ename (mapcar (function (lambda (%) (cons (cdr %) (car %)) ) ) (cd:DCT_GetDictList root T) ) ) ) ) (if (cd:DCT_RemoveDict root name) (progn (setq en (cd:DCT_AddXrecord root name Data)) (cd:DCT_GetXRecord en) ) ) ) ; =========================================================================================== ; ; Zmienia Xrecord / Change Xrecord ; ; Ename [ENAME] - nazwa entycji / entity name ; ; Data [list] - lista par kropkowych / list of dotted pairs ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCT_SetXrecordVLA ; ; (cdar (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T)) ; ; (list (cons 1 "NEW123") (cons 341 (car (entsel))))) ; ; =========================================================================================== ; (defun cd:DCT_SetXrecordVLA (Ename Data / n) (setq n (1- (length Data))) (vla-SetXRecordData (vlax-ename->vla-object Ename) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbInteger (cons 0 n) ) (mapcar (quote car) Data) ) ) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbVariant (cons 0 n) ) (mapcar (function (lambda (% / %1) (setq %1 (type %)) (cond ( (= %1 (quote ENAME)) (vlax-ename->vla-object %)) ( (= %1 (quote LIST)) (vlax-3d-point %)) (T %) ) ) ) (mapcar (quote cdr) Data) ) ) ) ) (cd:DCT_GetXRecord Ename) ) ; =========================================================================================== ; ; Zwraca wartosc danego klucza z listy asocjacyjnej / ; ; Returns the value of a key from assoc list ; ; Key [iNT] - klucz / key ; ; Data [list] - lista par kropkowych / list of dotted pairs ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DXF_Massoc 10 (entget (car (entsel)))) ; ; =========================================================================================== ; (defun cd:DXF_Massoc (Key Data / res tmp) (while (setq Data (member (setq tmp (assoc Key Data)) Data)) (setq res (cons (cdr tmp) res) Data (cdr Data) ) ) (reverse res) ) Quote Link to comment Share on other sites More sharing options...
