Lukijan Posted July 24, 2012 Share Posted July 24, 2012 Hi everybody! I'm trying to create dialog box for creating new layer, I googled everything I could remember, but I can't find anything. Set newLayer = ThisDrawing.Layers.Add("NameOfNewLayer") should create new layer, but how to define color or weight or type of lines? P.S. I'm using VB6... Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted July 25, 2012 Share Posted July 25, 2012 Lukijan, Never using VB6 I am only guessing. Set newLayer = ThisDrawing.Layers.Add("NameOfNewLayer") newlayer.color = ... newlayer.linetype = ... p.s. if your writing new code, Why not use VBA or vb.net? Quote Link to comment Share on other sites More sharing options...
Lukijan Posted July 25, 2012 Author Share Posted July 25, 2012 Yeah, but how to make colour palette? I'm making dialog box where user can choose colour for layer, line type, etc. Thanks, anyway! Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted July 26, 2012 Share Posted July 26, 2012 I recently looked into this, It is quite hard, When not using Arx. I do have code to create a Custom ComboBox for colors, but could not get the linetype bitmaps to work. I can give you the code if you like. The best solution I came up with was to use the AutoCAD Dialogue boxes. Linked to a datagrid form. Color Public Function UserGetColor() As Autodesk.AutoCAD.Colors.Color Dim DiaLineWT As New Autodesk.AutoCAD.Windows.ColorDialog Dim Result As System.Windows.Forms.DialogResult = DiaLineWT.ShowModal() If Result = System.Windows.Forms.DialogResult.OK Then Return DiaLineWT.Color Else Return Nothing End If End Function Line Weight Public Shared Function UserGetLineWeight() As LineWeight Dim DiaLineWT As New Autodesk.AutoCAD.Windows.LineWeightDialog Dim Result As System.Windows.Forms.DialogResult = DiaLineWT.ShowModal() If Result = System.Windows.Forms.DialogResult.OK Then Return DiaLineWT.LineWeight Else Return Nothing End If End Function Linetype Shared Function UserGetLineType() As LinetypeTableRecord Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Try Using tr As Transaction = db.TransactionManager.StartTransaction Dim ltt As LinetypeTable = tr.GetObject(db.LinetypeTableId, OpenMode.ForRead) Dim ltID As ObjectId = ShowLineTypeDialog() Dim ltr As LinetypeTableRecord = TryCast(tr.GetObject(ltID, OpenMode.ForRead, False), LinetypeTableRecord) If ltr IsNot Nothing Then Return ltr Else Return Nothing End If End Using Catch ex As Autodesk.AutoCAD.Runtime.Exception doc.Editor.WriteMessage(ex.Message) Return Nothing End Try End Function Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 26, 2012 Share Posted July 26, 2012 FWIW - Using Standard AutoCAD Dialogs to Select Colors, Linetypes, and Lineweights with .NET Quote Link to comment Share on other sites More sharing options...
Lukijan Posted July 30, 2012 Author Share Posted July 30, 2012 I'm using VB6, not VB.NET :/ Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 30, 2012 Share Posted July 30, 2012 I'm using VB6, not VB.NET :/ FWIW - Microsoft no longer supports VBA, and even Autodesk only provides access to VBAIDE via a separate download (it's no longer included with AutoCAD products). Presumably at some point (in the far future? ), VBA is going to die off through attrition, unless a rumored 'VBA7' is released. Keep that in mind when deciding which platform on which to develop your initiatives. Were Autodesk to stop offering the VBAIDE separate install, you'd be in a pinch. To that end, .NET & ObjectARX are quickly becoming Autodesk's development platforms of choice. You'd do well to start looking into it for that reason, and for accessing many of the new API Features that are only being exposed to .NET and ObjectARX. For simpler routines that you'd normally do in VBA, consider Visual LISP, as it also uses the ActiveX API. HTH Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 30, 2012 Share Posted July 30, 2012 More on VBA support, from the Autodesk Microsoft Visual Basic for Applications Module FAQ: What is the status of VBA support in the most recent releases of the AutoCAD product line? Microsoft made the decision to stop offering VBA distribution licenses to new customers as of July 1, 2007 and they have expressed that there are no plans to provide VBA product enhancements in the future. As a result of this, though Autodesk will continue to “unofficially” support VBA in its most recent releases of the products, software developers are strongly encouraged to base all future Microsoft Windows based development for AutoCAD based products on the Microsoft .NET Framework (VB .NET, C#, managed C++ etc). As first introduced with AutoCAD 2010, AutoCAD is not distributing VBA as part of the most recent AutoCAD installation disk. Rather, customers will need to download VBA here. What do you mean “unofficial” support for VBA? We will continue offering VBA as a download for customers, however, because Microsoft has discontinued support, we will only make a best efforts attempt to fix any defects and do not plan enhancements to VBA support in future product releases. What do you recommend for non-programmers to create simple scripts? .NET looks significantly harder to use than VBA. Though a little bit longer learning curve, we strongly recommend non-programmer’s get started customizing AutoCAD based on VB .NET using the free Microsoft VB Express. Developing .NET based applications with VB Express is a great no cost way to get started customizing AutoCAD that is easily extended if and when one wants to develop more powerful add-ons for AutoCAD. ... Quote Link to comment Share on other sites More sharing options...
