I don't think to be possible to curve an existing solid entity. Please check if the solution from this previous thread is useful for you.
Thanks so much, I don't know why I cannot see my post, let me show my project again:
file.php?id=11
Please show me how to make the chair back (the left solid) curve like the right solid.
This is the chair I'm trying to draw the chair back:
RP_1470086_S?wid=480&fmt=jpg&qlt=70&sa=X&ei=Zdv_T4ZPrbKJB-PzsaQL&ved=0CAkQ8wc4FQ&usg=AFQjCNF0BRsWsgHGTVw1WQk2v4DS-qxsFg
Curve an existing solid? I suppose it depends on what you mean exactly. Bend it?
ReMark, I think that OP's message was retained for moderation due to a link - he/she was looking to create a part for a curved chair.
Hi Msasu
Yes, I want to create a part of a chair back, 'cause working for a furniture factory, but I think that autocad cannot bend a solid with an arc, I just want to ask you if there is another way to do so, as this's beyond my reach. I don't want to use pro engineer, solidworks....
By the way, could s.o tell me why I cannot see my post
Regards.
Could s.o please tell me how to make the left solid curve like the right one please?
  thanhlt said:
[ATTACH=CONFIG]35934[/ATTACH]
Maybe it's possible in Inventor but in AutoCAD I would say it is impossible to bend the one on the left. However, I think you might be able to approximate it. Can you post and actual DWG file?
If you read again the above posts, will find the answers to both questions, but I will resume them for you.
I believe that is being held temporary for moderation due to the link you inserted - please check the Forum rules. Just be patient, please.
Check the method I suggested in this thread; use the items from your picture, just extrude more the shape on the left and intersect it with the shape from the right side.
There isn't a bend command in AutoCAD, but I don't see why the part couldn't be made in AutoCAD from a Thickened trimmed surface.
Use PRESSPULL, and do as Mircea suggests, creating enough depth on the left side flat piece to use the INTERSECT or INTERFERE command to create a new part from the common shared volumes in those 2 shapes. :)
nestly did a nice video which will show you how to do this within the last 3 weeks, showing how to model an offset wrench.
Project geometry works too.
just cut that shape out and your good to go
INTERSECT, as mentioned above, will give a reasonable representation, but not exactly as it's likely to be manufactured.
Hi Nestly,
Thanks for the nice illustration, but I see that it cannot be exactly. As the part is curve and all the holes inside should be curve too, haiz, thank everybody, and I appreciate if s.o can figure out how to do this exactly.
  thanhlt said:
Hi Nestly,
As nestly mentioned it is not exactly as it would be if bent, but that could be done by orienting the elements to be subtracted radially. :)
Once again, JD's solution, on second perusal, is spot on. :beer:
