Try this ... :)
(defun c:Test (/ *error* p1 p2 e w)
 (vl-load-com)
 ;;; Tharwat 11. July. 2012  ;;;
 (defun *error* (msg)
       (princ (strcat "\n** Error: " msg " **"))
 (if (not (tblsearch "LAYER" "A-Wall-Patt"))
   (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord")
                  '(2 . "A-Wall-Patt") '(62 . 252) '(70 . 0))
 (if (and (setq p1 (getpoint "\n Specify first point :"))
          (setq p2 (getpoint p1 "\n Next point :"))
   (setq e (entmakex (list '(0 . "LWPOLYLINE")
                           '(100 . "AcDbEntity")
                           '(100 . "AcDbPolyline")
                           '(8 . "A-Wall-Patt")
                           '(90 . 2)
                           '(70 . 0)
                           (cons 10 (trans p1 1 0))
                           (cons 10 (trans p2 1 0))
 (if (setq w (getdist "\n Specify width of Polyline :"))
     (vla-put-constantwidth (vlax-ename->vla-object e) w)
  • Replies 27
  • Grigs
    14
  • Tharwat
    10
  • MSasu
    3
  • SLW210
    1
Posted Images
Tharwat
I really appreciate all the help you've given me. One last thing. 'w' defines the width of the polyline. What if I wanted the width to be 0.5 inches less than the picked width? How would that code be implemented.
  • 2 weeks later...
Tharwat, the lisp routine works well. I just have 1 question. Is it possible to alter the lisp to that you can pick multiple points? For instance, if you had a corner situation. The lisp would let you keep picking points then you would pick the 2 points that define the width and the entire polyline would be that width.
Is this what you mean ..... ?
(defun c:Test (/ *error* e w)
 (vl-load-com)
   (or    (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
 )(setq e nil)
   (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord" ) '(100 . "AcDbLayerTableRecord" )
          '(70 . 0))
 (command "_.pline")
 (while (eq (getvar 'cmdactive) 1) (command pause))
   (progn (vla-put-layer
        (setq e (vlax-ename->vla-object (entlast)))
        "A-Wall-Patt"
      (vla-put-constantwidth e w)
Once again you came thru for me. Works perfectly. Thanks!!!
You're welcome any time . :)
