MSasu Posted July 11, 2012 Posted July 11, 2012 Did you tested the above code? I just want to make sure of columns location. Quote
MSasu Posted July 11, 2012 Posted July 11, 2012 This will convert a file from one format to another - you should adjust the width of the columns if case: ;;; Convert for Teknomatika's Data File (11-VII-2012) (defun c:CTDF( / widthColumns fileOld fileNew streamOld streamNew stringOld stringNew indexColumn ) ;"5001100926.946000096.8278000221.264000NL" (vl-load-com) (setq widthColumns '(8 10 10 10)) [color=red]<-- Validate the width of the data columns !!![/color] (if (setq fileOld (getfiled "Select file to convert" "C:\\" "*" 0)) (progn (setq fileNew (strcat (vl-filename-directory fileOld) (vl-filename-base fileOld) "_fixed" (vl-filename-extension fileOld))) (setq streamOld (open fileOld "r") streamNew (open fileNew "w")) (while (setq stringOld (read-line streamOld)) (setq indexColumn 1 stringNew "") (foreach widthTemp widthColumns (setq stringNew (strcat stringNew "," (substr stringOld indexColumn widthTemp)) indexColumn (+ indexColumn widthTemp)) ) (setq stringNew (strcat (substr stringNew 2) "," (substr stringOld indexColumn))) (write-line stringNew streamNew) ) (setq streamOld (close streamOld) streamNew (close streamNew)) (startapp "NOTEPAD" fileNew) ) ) (princ) ) (Sorry, but I cannot test it right now.) Quote
teknomatika Posted July 11, 2012 Author Posted July 11, 2012 This will convert a file from one format to another - you should adjust the width of the columns if case: ;;; Convert for Teknomatika's Data File (11-VII-2012) (defun c:CTDF( / widthColumns fileOld fileNew streamOld streamNew stringOld stringNew indexColumn ) ;"5001100926.946000096.8278000221.264000NL" (vl-load-com) (setq widthColumns '(8 10 10 10)) [color=red]<-- Validate the width of the data columns !!![/color] (if (setq fileOld (getfiled "Select file to convert" "C:\\" "*" 0)) (progn (setq fileNew (strcat (vl-filename-directory fileOld) (vl-filename-base fileOld) "_fixed" (vl-filename-extension fileOld))) (setq streamOld (open fileOld "r") streamNew (open fileNew "w")) (while (setq stringOld (read-line streamOld)) (setq indexColumn 1 stringNew "") (foreach widthTemp widthColumns (setq stringNew (strcat stringNew "," (substr stringOld indexColumn widthTemp)) indexColumn (+ indexColumn widthTemp)) ) (setq stringNew (strcat (substr stringNew 2) "," (substr stringOld indexColumn))) (write-line stringNew streamNew) ) (setq streamOld (close streamOld) streamNew (close streamNew)) (startapp "NOTEPAD" fileNew) ) ) (princ) ) (Sorry, but I cannot test it right now.) Mircea, Excellent. It works well. I note also that I can control the position or the introduction of the comma separator editing the variable widthColumns Fantastic. Thanks for the help. Quote
MSasu Posted July 11, 2012 Posted July 11, 2012 Glad to hear that it works well - I was expecting tomorrow morning to be able to test it. You're entirely welcome! Quote
pBe Posted July 12, 2012 Posted July 12, 2012 (edited) FWIW: If length is indeed constant (defun c:demo (/ data) (setq data '("09F15004128012.1640000103.357600113.245600OD" "09F1500412818.69700000100.978600142.721400RD" "09F1500412824.80900000101.967000112.053400RD" "09F1500412834.72000000101.520800112.992800RD" "09F1500412843.94700000102.08440067.2318000RD" "09F1500412851.67800000103.435000351.147600RD" "09F1500412861.76000000103.541200226.526200RD" "09F1500412878.81200000100.714400187.285600RD")) (foreach str Data (print (strcat (substr str 1 (apply 'strcat (mapcar (function (lambda (j) (strcat "," (substr str (car j) (cadr j))))) '((9 4) (13 10) (23 10) (33 10) (43 2)))))) ) (princ) ) Command: demo "09F15004,1280,12.1640000,103.357600,113.245600,OD" "09F15004,1281,8.69700000,100.978600,142.721400,RD" "09F15004,1282,4.80900000,101.967000,112.053400,RD" "09F15004,1283,4.72000000,101.520800,112.992800,RD" "09F15004,1284,3.94700000,102.084400,67.2318000,RD" "09F15004,1285,1.67800000,103.435000,351.147600,RD" "09F15004,1286,1.76000000,103.541200,226.526200,RD" "09F15004,1287,8.81200000,100.714400,187.285600,RD" Dmo2 (defun c:demo2 () (defun _split (str) (mapcar (function (lambda (j) (substr str (car j) (cadr j)))) '((9 4) (13 10) (23 10) (33 10) (43 2)))) (setq data '("09F15004128012.1640000103.357600113.245600OD" "09F1500412818.69700000100.978600142.721400RD" "09F1500412824.80900000101.967000112.053400RD" "09F1500412834.72000000101.520800112.992800RD" "09F1500412843.94700000102.08440067.2318000RD" "09F1500412851.67800000103.435000351.147600RD" "09F1500412861.76000000103.541200226.526200RD" "09F1500412878.81200000100.714400187.285600RD" ) codelist nil ) (foreach stringOld Data (if (setq code (assoc (setq StationCode (substr stringOld 1 ) codelist)) (setq codelist (subst (cons (car code)(list (append (cadr code) (list (_split stringold))))) code codelist)) (setq codelist (cons (list StationCode (list (_split stringOld))) codelist)) ) ) (foreach df codelist (print (car df)) (foreach itm (cadr df) (print itm)(princ)) ) ) Command: demo2 "09F15004" ("1280" "12.1640000" "103.357600" "113.245600" "OD") ("1281" "8.69700000" "100.978600" "142.721400" "RD") ("1282" "4.80900000" "101.967000" "112.053400" "RD") ("1283" "4.72000000" "101.520800" "112.992800" "RD") ("1284" "3.94700000" "102.084400" "67.2318000" "RD") ("1285" "1.67800000" "103.435000" "351.147600" "RD") ("1286" "1.76000000" "103.541200" "226.526200" "RD") ("1287" "8.81200000" "100.714400" "187.285600" "RD") HTH Edited July 12, 2012 by pBe Quote
teknomatika Posted July 12, 2012 Author Posted July 12, 2012 Pbe, Being different from the solution of Mircea, works equally well. Thanks for the help. It was very important. Quote
pBe Posted July 12, 2012 Posted July 12, 2012 Pbe,Being different from the solution of Mircea, works equally well. Thanks for the help. It was very important. Good for you, Both codes are not complete. it just shows you how to parse the string after "reading" the file. The frist demo rouitne will add the "comma" separator and you can overwrite or create a new file similar to MSasu's code. The second Demo rouitne demonstrates splitting the string to a list (Station code (( "point number" "X" "Y" "Z" "Code Point")( "point number" "X" "Y" "Z" "Code Point")....) ready for whatever purposes. its a direct way of reading and using the data without re-writing the source data Glad you find it useful Cheers Quote
