bachrock Posted July 10, 2012 Share Posted July 10, 2012 This mtext won't rotate. When I use the rotate command, the text moves around a point, but stays right side up the whole time. I remember this happening with xrefs as well. Anyone know what's happening here? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2012 Share Posted July 10, 2012 You have selected "Match Text Orientation to Layout" in Text Style. Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 10, 2012 Author Share Posted July 10, 2012 (edited) You have selected "Match Text Orientation to Layout" in Text Style. Great, thanks! EDIT: I had assumed that would work, but it didn't. I see some text styles have that box checked while others do not. Regardless of the text style, the text won't rotate as I want it to. Edited July 11, 2012 by bachrock Tip didn't end up working Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 11, 2012 Author Share Posted July 11, 2012 You have selected "Match Text Orientation to Layout" in Text Style. That didn't seem to do it. Any other ideas? Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 11, 2012 Share Posted July 11, 2012 May be useful to attach the drawing here for further investigation. Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 11, 2012 Author Share Posted July 11, 2012 May be useful to attach the drawing here for further investigation. I went to attach the drawing and got an ioError. The file is 0.98 MB so size shouldn't be the issue... Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 11, 2012 Share Posted July 11, 2012 Just strip out any other elements except the trouble-maker label prior to load. Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 11, 2012 Author Share Posted July 11, 2012 Just strip out any other elements except the trouble-maker label prior to load. I understand that sentence up to "prior to load". Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 11, 2012 Share Posted July 11, 2012 Remove all from the drawing (a copy of the drawing would be best) to reduce size and then upload to CADTutor. Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 11, 2012 Author Share Posted July 11, 2012 Remove all from the drawing (a copy of the drawing would be best) to reduce size and then upload to CADTutor. Yeah, that's what I had done. Is 1 MB too large? That was my only guess as it didn't seem to describe the error. EDIT: I had originally deleted most of the drawing and now just deleted all of the linework except the one bit of mtext. The file size is still the same 1 MB. Not sure why a bit of Mtext would generate such a large file. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 11, 2012 Share Posted July 11, 2012 Did you -PURGE the file (notice the - in front)? Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 11, 2012 Author Share Posted July 11, 2012 Did you -PURGE the file (notice the - in front)? No, is the idea that that will remove all these unused blocks and such that are making the file so large? Do you know what the file size limit is for attachments? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 12, 2012 Share Posted July 12, 2012 Yes 1000kb limit for .dwg and .dxf Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 12, 2012 Author Share Posted July 12, 2012 Yes 1000kb limit for .dwg and .dxf I did some purging. The new file size is 947 kb. It still won't attach though. No idea why. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 12, 2012 Share Posted July 12, 2012 Can you use dropbox? Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 12, 2012 Author Share Posted July 12, 2012 Can you use dropbox? Unfortunately not. This is all for work and they have it blocked here. There's the old add an "s" to "http" trick, but that doesn't work for most sites including dropbox. Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 12, 2012 Share Posted July 12, 2012 Can you try please to transfer the trouble-maker text entity to a new, empty drawing? Just test if still present the said behavior and try to attach that file - it should be considerably smaller then current one. Quote Link to comment Share on other sites More sharing options...
rickh Posted July 12, 2012 Share Posted July 12, 2012 Is it possible the text you are trying to rotate is a civil 3d label and not mtext? Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 12, 2012 Author Share Posted July 12, 2012 Is it possible the text you are trying to rotate is a civil 3d label and not mtext? Under properties the text is listed as Mtext. Quote Link to comment Share on other sites More sharing options...
bachrock Posted July 12, 2012 Author Share Posted July 12, 2012 Can you try please to transfer the trouble-maker text entity to a new, empty drawing? Just test if still present the said behavior and try to attach that file - it should be considerably smaller then current one. I would think that file would be considerably smaller as well, but it is not. The same thing happens to the text. Quote Link to comment Share on other sites More sharing options...
