Daf Posted July 10, 2012 Share Posted July 10, 2012 (edited) I have a rather unusual problem. I'm using AutoCADLT2013. I have a dynamic block, with chained parameters. The block works perfectly, however, I'm expanding the contents, and trying to add more polylines to existing actions. I have the following Actions showing: Stretch, Lookup, and Visibility. All of these actions are on unchained Parameters. The 2 Actions I'm missing are Arrays, both on chained Parameters with no Grips. I've used BACTIONBAR on both Parameters (Show, then Hide, then Show again, I don't want to use Reset!), yet the Action Bars still won't show! I've been messing for nigh on 2 hours and I can't figure it out. To make things worse, I can't use the Parameter Manager, due to it disappearing when in Block Editor. I really don't want to have to start again, as it was a right pain in the rectum to get to work right. Any ideas? Edited July 10, 2012 by Daf Quote Link to comment Share on other sites More sharing options...
Daf Posted July 10, 2012 Author Share Posted July 10, 2012 Ok, never mind. I bit the bullet and used Reset in BACTIONBAR. The end of the world didn't happen, and everything is hunky dory. Cheers anywho. Quote Link to comment Share on other sites More sharing options...
KoTa04 Posted July 10, 2012 Share Posted July 10, 2012 Wow, I had the same problem today too, and so I did what you did.. Hit reset, the thing is, all my action bars came back up again!! They didn't die! Quote Link to comment Share on other sites More sharing options...
Daf Posted July 11, 2012 Author Share Posted July 11, 2012 Yeah, funny that. I was expecting the actions to lose all their properties. Turns out Reset = Purge Bugs. Quote Link to comment Share on other sites More sharing options...
