saunambon654 Posted June 5, 2023 Posted June 5, 2023 mhupp, I think you forgot cases for special letter, be like @ *#. Quote
mhupp Posted June 5, 2023 Posted June 5, 2023 (edited) Tech you don't need to split up numbers and letters. But I just liked how it looked. so you don't really even need to test for anything. The lisp below just puts each char in brackets and works the same. ;;----------------------------------------------------------------------------;; ;; Generate a text search that ignores Case Senesitivity. ;; saunambon654, Lee Mac, mhupp ;; https://www.cadtutor.net/forum/topic/39880-case-sensitivity/#comment-618863 ;; (ssget "X" (list '(0 . "TEXT") (cons 1 (IC "Floor9")))) ;; (ssget "X" '((0 . "TEXT") (1 . "[Ff][Ll][Oo][Oo][Rr][99]"))) (defun IC (str1 / str2 i) (if (= (type str1) 'STR) (progn (setq str2 "" i 1) (repeat (strlen str1) (setq x (substr str1 i 1)) (setq str2 (strcat str2 "[" (strcase x) (strcase x T) "]")) (setq i (1+ i)) ) ) ) str2 ) So this would generated (ssget "X" '((0 . "TEXT") (1 . "[Ff][Ll][Oo][Oo][Rr][99]"))) It would find all values for Floor9, but not Floor99. Edited June 5, 2023 by mhupp Quote
saunambon654 Posted June 5, 2023 Posted June 5, 2023 1 minute ago, mhupp said: Tech you don't need to split up numbers and letters. But I just liked how it looked. so you don't really even need to test for anything. The lisp below just puts each char in brackets and works the same. ;;----------------------------------------------------------------------------;; ;; Generate a text search that ignores Case Senesitivity. ;; saunambon654, Lee Mac, mhupp ;; https://www.cadtutor.net/forum/topic/39880-case-sensitivity/#comment-618863 ;; (ssget "X" (list '(0 . "TEXT") (cons 1 (IC "Floor9")))) ;; (ssget "X" '((0 . "TEXT") (1 . "[Ff][Ll][Oo][Oo][Rr][99]"))) (defun IC (str1 / str2 i) ;ignore case (if (= (type str1) 'STR) (progn (setq str2 "" i 1) (repeat (strlen str1) (setq str2 (strcat str2 "[" (strcase x) (strcase x T) "]"))) (setq i (1+ i)) ) ) ) str2 ) So this would generated (ssget "X" '((0 . "TEXT") (1 . "[Ff][Ll][Oo][Oo][Rr][99]"))) It would find all values for Floor9, but not Floor99. Of course you could do it, we just find the best way. If your string is long (hundreds of letters) it will be effect to speed calculation. Quote
Lee Mac Posted June 5, 2023 Posted June 5, 2023 Here's another way to write it - (defun casesensitivity ( s ) (vl-list->string (apply 'append (mapcar '(lambda ( a b ) (if (= a b) (list a) (list 91 a b 93))) (vl-string->list (strcase s)) (vl-string->list (strcase s t)) ) ) ) ) As for combinations, maybe something like this - (defun combinations ( s / foo ) (defun foo ( u l ) (if (cdr u) (append (mapcar '(lambda ( x ) (cons (car u) x)) (foo (cdr u) (cdr l))) (mapcar '(lambda ( x ) (cons (car l) x)) (foo (cdr u) (cdr l))) ) (list u l) ) ) (mapcar 'vl-list->string (foo (vl-string->list (strcase s)) (vl-string->list (strcase s t)) ) ) ) _$ (length (combinations "floor")) 32 3 Quote
