19cruthik68 Posted July 3, 2012 Posted July 3, 2012 I dont know what happened when i opened my autocad it looks like the image below also if i will right click on the drawing space, nothing happens, but below or in the command window, i can, also for example i drew a line, and i want to redo, the "CTRL" function using ctrl+Z is disabled, what happened with this one? anyone knows? Quote
ReMark Posted July 3, 2012 Posted July 3, 2012 Did you inadvertently hit the "Clean Screen" button? Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 as what i've said, control function is disabled, i dont know why, but in ms word it is working, only on my autocad, also i cannot right click on the drawing space, Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 i tried that already ctrl+0 nothing happens Quote
ReMark Posted July 3, 2012 Posted July 3, 2012 Have you tried shutting your computer down then restarting it? I mean a cold boot not a warm boot via Ctrl+Alt+Del. Have you tried changing Workspaces? Have you tried resetting your Profile? Quote
nestly Posted July 3, 2012 Posted July 3, 2012 Looks like the CUI is not loaded... (CUI also stores right-click and Shortcut keys) Try restarting AutoCAD , changing profiles then changing back, using CUILOAD Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 what do you mean? can you elaborate, i dont know how to deal with this one. thanks Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 Looks like the CUI is not loaded... (CUI also stores right-click and Shortcut keys) Try restarting AutoCAD , changing profiles then changing back, using CUILOAD can you show me the step regarding this? Quote
ReMark Posted July 3, 2012 Posted July 3, 2012 You can change a Profile by going to Options > Profile tab. CUILOAD is invoked from the command line. Quote
nestly Posted July 3, 2012 Posted July 3, 2012 Type OPTIONS, then select the "Profiles" tab. If there are more than one profile listed, pick another then click "Set Current" If anything changes, then repeat to return to your original profile Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 Have you tried shutting your computer down then restarting it? I mean a cold boot not a warm boot via Ctrl+Alt+Del. Have you tried changing Workspaces? Have you tried resetting your Profile? i tried already, except for number two, because i cant change the workspace,. Quote
19cruthik68 Posted July 3, 2012 Author Posted July 3, 2012 Type OPTIONS, then select the "Profiles" tab. If there are more than one profile listed, pick another then click "Set Current" If anything changes, then repeat to return to your original profile im done with that, options --> prfiles tab. the name appears there is only unnamed profile Quote
