Sheet metal drawing
Welcome to the forum. :)
Being a SOLIDWORKS specific question, you would likely be better served to put it in the SOLIDWORKS forum, where you know that Solidworks users will see it. :)
What version of SolidWorks are you using? 2010? 2011? 2012?
How many parts will make up the real world assembly? 1? 4? More?
Where are the rips or seams?
More information is needed.
Dear JD,
Solidworks standard 2012, no idea about number of assemblies.
kahaduwap
How much experience do you have using Solidworks?
Only for two months
Dear JD,
kahaduwap
Not assemblies. Parts. How many sheets of metal will be folded to make one of these.
What is the thickness of the material?
I will try to post an example later today of one possible solution.
Only for two months
How many drawings have you done so far of this nature?
One for top part and four for four bottom sides. Thickness is 0.75 mm
