Hi,
I am looking for LISP application that can do the following:
1. Manage a Library of Blocks (the blocks can be of two types: a drawing with numerous blocks or a folder with each block written to a dwg file)
2. Open a Block and turn first-level elements color and linetype to BYBLOCK
Thanks you in advance.
1 How do you intend "managing", a txt list, a visual display, know its name there is various methods why not palletes, I use menus with sld's ? first part insert second part would be BYBLOCK.
2 The code do BYBLOCK this will be here did you try a search.
