Start Line command, type PER, enter, pick line, move cursor, pick again.
This is for starting at an endpoint and perpendicular but this will work for you also.
Draw a line perpendicular to the endpoint of a line.
1. OTRACKING on,OSNAP endp and perp set, POLAR on, start line command,
acquire end point, move 90 degrees in direction you want, type the
value or pick, pick the point you first acquired.
2. Rotate the UCS with the OBject option, and draw away. I have this
automated with UO as my quick keys (UCS, OBject), and to go back I use
UW (UCS, World).
3. With POLAR set to Relative to last point, start the line command,
use an osnap, pick the line, move 90 degrees in the direction you
want to draw and enter
the value or pick.
4. Rotate the crosshairs with snap, rotate, pick two points on the
line, ... This is also easily automated with a lisp so you can pick
the line and have the crosshairs rotate.
I am sure there are others.
With a lisp its easy you also get the option of how far from end of line. Will have a look for code its at home.
Edit: Removed.... 100% similar to rkent idea (see first line of his post)
Damn.. this is second time last week when it happens to me... I should start reading other`s posts :(
Edited by Stefan BMR
Same as above. This is AutoCAD2011, but I believe 2005 is the same, less the Dynamic Cursor input.
