razmatazbaz Posted June 26, 2012 Posted June 26, 2012 I'm currently learning myself on architecture revit 2012. have got the hang of it pretty quickly and i'm knocking out models pretty quick but the only real problem i've encountered so far is window cills. Can't seem to find the option to use concrete cills when im putting a window on a wall. Can't find anything on it. This is probably a really silly question but any help would help a lot, thanks Quote
ReMark Posted June 27, 2012 Posted June 27, 2012 (edited) Try changing your search criteria to "sill" which is the correct way of spelling the word. You wouldn't be using a brick and CMU cavity wall would you? Edited June 27, 2012 by ReMark Quote
razmatazbaz Posted June 27, 2012 Author Posted June 27, 2012 people spell it 'cill' or 'sill' were i'm from mark. will try that now Quote
ReMark Posted June 27, 2012 Posted June 27, 2012 Are you utilizing a brick and CMU cavity wall in your building construction? Quote
ReMark Posted June 27, 2012 Posted June 27, 2012 Maybe this will be of some help. http://www.sdcpublications.com/pdfsample/978-1-58503-675-2-3.pdf Quote
razmatazbaz Posted July 1, 2012 Author Posted July 1, 2012 Are you utilizing a brick and CMU cavity wall in your building construction? yes. doing a brick cavity wall. looking to put a precast concrete sill with the window. On the old autocad the sill used to come when you placed the window. was just a case of clicking the box if you wanted to use one or not. Quote
