Taochuen Posted June 25, 2012 Posted June 25, 2012 Maybe someone can help me out here. Is it possible that I can create a link between dimensions (width & length) of a rectangle in AutoCAD, and two cells in a pre-existing Excel sheet; so when I modify the size of this rectangle in AutoCAD, the cells will also get updated? I'm using AutoCAD 2002, 2006 & Excel 2003. Quote
ReMark Posted June 25, 2012 Posted June 25, 2012 Read this: http://www.cadtutor.net/forum/showthread.php?56228-Can-you-link-excel-cells-to-dimensions Quote
Taochuen Posted June 26, 2012 Author Posted June 26, 2012 Thanks for the reply, that seems to be a promising solution. The problem to me is that AutoCAD 2006 doesn't support data link from CAD Table to Excel cells (correct me if I'm wrong), thus my updated dimension data will still be stuck in AutoCAD and finding no way out. Quote
ReMark Posted June 26, 2012 Posted June 26, 2012 You're right...my bad. There are programs that can establish a link between AutoCAD and Excel. Quote
