User2012 Posted June 25, 2012 Posted June 25, 2012 When I want to save the Solidworks file in the Cad format.dwg. I get the "Property Manager" window. What is this about? I just want to convert solidworks file to dwg. and then work on it in CAD. Quote
Patrick Hughes Posted June 25, 2012 Posted June 25, 2012 Well it looks like it's just presenting you some save options. What happens when you click on the green check mark? If it's not working for you I've discovered that the free Inventor Fusion program will convert SolidWorks file to .dwg. Quote
Grant Posted June 26, 2012 Posted June 26, 2012 Maybe save as a Parasolid - 'back a few versions' for Autocad to pick up. Quote
User2012 Posted June 27, 2012 Author Posted June 27, 2012 I thought it might be an easier choice to convert it to dwg in solidworks directly. However, it gave me a 2D view of the face selected! Either solidworks or parasolid formats can be conveted to dwg through the Inventor! Quote
shift1313 Posted July 5, 2012 Posted July 5, 2012 Basically its asking you what view you want to convert to a dwg since you are going from 3d to 2d. Another way you can do this is select a face and Right-click and choose "export face as dwg/dxf". SW just needs to know more information before it flattens it into 2d. Quote
User2012 Posted July 5, 2012 Author Posted July 5, 2012 Inside the Solidworks environment, is there another way to convert a 3D model to a 3D. dwg, directly? Quote
shift1313 Posted July 5, 2012 Posted July 5, 2012 not that i know of. everything is 2d. out of curiosity why would you want to export from solidworks to work in acad? Quote
User2012 Posted July 5, 2012 Author Posted July 5, 2012 Because I don't have both programs on the same computer, so sometimes I just have access to AutoCAD. Quote
