kapricious Posted June 21, 2012 Posted June 21, 2012 Normally I create parts from scratch and produce drawings from the parts files I've created. However, this time, my work sent a STP (STEP) file which contains numerous pieces and I'm supposed to do drawings for each of the individual parts. But I can't figure out how to get the parts separated into parts files to do drawings from (and that's the only way I know how to produce drawings). It seems I can only isolate and export the various pieces in into DWG/DWF format. I tried this, but when I open them, I can't figure out how to export them to parts files or do drawings from them. I have tried googling dozens of different keywords all morning but haven't seem to come across whatever I am missing here. Any help would greatly be appreciated. Thanks in advance Quote
kapricious Posted June 21, 2012 Author Posted June 21, 2012 @f700es: Unfortunately, I cannot. It's a confidential prototype. @SLW210: Inventor -- I'm sorry, can't believe I didn't include that info. Quote
JD Mather Posted June 21, 2012 Posted June 21, 2012 This is a little out of date (if you are using 2012 or 2013) http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf Quote
Bishop Posted June 22, 2012 Posted June 22, 2012 When I import a STEP file into 2011, it automatically creates an assembly for me with multiple individual .IPT's, if there's more than one body in the part ... from there, it shouldn't be any difficulty to create drawings of each .IPT. Quote
