sinbad92 Posted June 21, 2012 Posted June 21, 2012 Anyway so here's the problem: I am struggling to edit the standard set of blocks that comes with AutoCAD such as receptacles junction boxes etc. I want to edit the standard blocks and then save my changes for future use. Right now the blocks come in at different sizes then I would like. I try to edit them in the block editor however the changes I make only apply to the drawing I am currently working on. The changes do not apply across the board on all drawings in all files. Please help me, any and all help would be hugely appreciated! Thank you! Quote
tzframpton Posted June 21, 2012 Posted June 21, 2012 Are you trying to edit the AEC Objects from AutoCAD MEP? Or are you editing the standard 2D blocks from vanilla AutoCAD? If you are trying to edit the AutoCAD MEP ones, there's a process you have to follow. Quote
sinbad92 Posted June 22, 2012 Author Posted June 22, 2012 Yes, precisely. I am trying to edit the AEC Objects from AutoCAD MEP. If you could help me through the process or point me in the right direction i would really appreciate that. Quote
