ml3428 Posted June 20, 2012 Share Posted June 20, 2012 I came across the attached LISP routine that allows attribute information to be extracted into an excel document. Unfortunately this code searches the entire drawing for attributes, when I need only specific blocks to be selected. I am looking to modify the following code, so that it will prompt me for a selection window when extracting specific block attributes in a drawing. If anyone can help me with this I would appreciate, as I have no experience writing or modifying LISP. Thank You ATTOUT.LSP Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 20, 2012 Share Posted June 20, 2012 Global Attribute Extractor and Editor by Lee Mac. Extracts attributes to Excel. http://lee-mac.com/macatt.html Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 20, 2012 Share Posted June 20, 2012 The code posted already had options for what you were looking for; just adjust the code as below: 1. To select the blocks you want to extract ;; variations of the selection ;; All blocks : [color=red];;;[/color] (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1)))) ;; Selected on screen: [color=blue](setq ss (ssget '((0 . "INSERT"))))[/color] ;; All blocks by name: ;;; (setq bname (getstring "\n *** Block name:\n")) ;;; (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1) (cons 2 bname)))) 2. To indicate blocks to extract by their name: ;; variations of the selection ;; All blocks : [color=red];;;[/color] (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1)))) ;; Selected on screen: ;;;(setq ss (ssget '((0 . "INSERT")))) ;; All blocks by name: [color=blue] (setq bname (getstring "\n *** Block name:\n")) (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1) (cons 2 bname))))[/color] Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 20, 2012 Author Share Posted June 20, 2012 MSasu Thanks for the help!!, the first code you posted solved the problem for me. Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 20, 2012 Share Posted June 20, 2012 Glad to hear that you got this solved! Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 20, 2012 Author Share Posted June 20, 2012 In addition to extracting attribute information to an excel table, I am also looking for a similar way to generate a BOM table to insert into AutoCAD. If anyone has used or knows of a LISP to accomplish this I would greatly appreciate it. Thank You Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 20, 2012 Author Share Posted June 20, 2012 Mircea, I have one more request in looking to revise this code. Right now a column is being created that lists the "handle" of the bolck attribute. I would like to revise the code so that this column will not display, but keep all other tags assoicated with the routine. Hopefully this is an easy fix. I attached the revised LISP for you to look at. (setq header_list '("HANDLE" Not Needed "BLOCK NAME" "SECTION NO" "FAMILY" "DESCRIPTION" "PN" Thank You ATTOUT.LSP Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 21, 2012 Share Posted June 21, 2012 Msasu a suggestion rather than "getstring block name" use a pick block and return block name nothing worse than 11 finger typing. (setq en1 (car (entsel "\nSelect Block:" ))) (setq el1 (entget en1)) (setq BLKname (cdr (assoc 2 el1))) Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 21, 2012 Share Posted June 21, 2012 Bigal, that code is from OP’s routine; the alternative input methods were already there and commented out. I just showed him/her how to adjust it to work as expected. For sure your solution is much flexible than the one form original code. Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 21, 2012 Share Posted June 21, 2012 Please find below the adjusted code to get rid of the handle column from the report: [color=magenta]...[/color] (setq header_list '([color=red];[/color][color=dimgray]"HANDLE"[/color] "BLOCK NAME" "SECTION NO" "FAMILY" "DESCRIPTION" "PN" ) ) ;_ end of setq [color=magenta]...[/color] (setq row 2 colm 1 ) (repeat (length exc_data) (setq data [color=red](cdr[/color] (reverse (cdr (reverse (car exc_data))))[color=red])[/color] subtot (last (car exc_data)) ) [color=magenta]...[/color] Also, there was a very ineffective solution to indicate the destination file - have changed that too. (setq fn (vl-filename-base (getvar "dwgname"))) (setq fname (strcat (getvar "dwgprefix") fn ".xls")) (setq [color=red]fx[/color] (open fname "W")) (close [color=red]fx[/color]) [color=red];;;[/color][color=dimgray](alert (strcat "Select file " "\"" (strcat fn ".xls") "\""))[/color] [color=red];;;[/color][color=dimgray](setq fname (getfiled "Excel Spreadsheet File" "" "XLS" )[/color] [color=red];;;[/color][color=dimgray](setq fname (findfile fname))[/color] There is another pending improvment, regarding the saving of the file; if will have time later will try to fix that too. Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 21, 2012 Author Share Posted June 21, 2012 Mircea, Thank You again for the help. However, when I try to run this code it eliminates the handle column, but no longer extracts the attributes for the other columns. I am unsure if it is an error on my part, but I have tried modifying the code several times with the same result. Thanks Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 21, 2012 Share Posted June 21, 2012 Can you post please the modified code? Thank you. Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 21, 2012 Author Share Posted June 21, 2012 Here is the modified code. I am sure it is an error on my part, and truly do appreciate all the help with this!! Thank You ATTOUT(REVISED).LSP Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 22, 2012 Share Posted June 22, 2012 Please check if this is what you were looking for: ;; Groups elements in sublist by criteria (defun subtrack (test lst) (apply 'append (mapcar '(lambda (x) (if (eq (car x) test)(list x))) lst))) ;; Counts equivalent subs in list (defun countsub (lst sub) (cond ((null lst) 0) ((and (equal (caar lst) (car sub) 0.00001) (equal (cadar lst) (cadr sub) 0.00001) ) (1+ (countsub (cdr lst) sub)) ) (T (countsub (cdr lst) sub)) ) ) ;; Get info from block include from constant attributes in following form: ;; (("TAG1" . "VALUE1") ("TAG2" . "VALUE2") ...("*CONSTANT*: TAGN" . "VALUEN")) (defun get-all-atts (obj / atts att_list const_atts const_list ent) (and (if (and obj (vlax-property-available-p obj 'Hasattributes) (eq :vlax-true (vla-get-hasattributes obj)) ) (progn (setq atts (vlax-invoke obj 'Getattributes)) (foreach att atts (setq att_list (cons (cons (vla-get-tagstring att) (vla-get-textstring att) ) att_list ) ) ) ) ) ) (cond ((vlax-method-applicable-p obj 'Getconstantattributes) (setq const_atts (vlax-invoke obj 'Getconstantattributes)) (foreach att const_atts (setq const_list (cons (cons (vla-get-tagstring att) (vla-get-textstring att) ) const_list ) ) ) (setq att_list (reverse (append const_list att_list))) ) (T (reverse att_list)) ) ) ;; Main part ;; (defun C:ATOUT (/ acsp adoc aexc awb axss bname cll colm com_data csht data exc_data fname header_list info nwb osm row sht ss str1 str2 subtot tmp_data tmp_get tmp_snip tot fx ) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) acsp (vla-get-modelspace adoc) ) (setq osm (getvar "osmode")) (setvar "osmode" 0) (setvar "cmdecho" 0) (vla-endundomark adoc) (vla-startundomark adoc) (vl-cmdf "zoom" "a") (vl-cmdf "zoom" ".85x") ;; variations of the selection ;; All blocks : ;;; (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1)))) ;; Selected on screen: (setq ss (ssget '((0 . "INSERT")))) ;; All blocks by name: ;;; (setq bname (getstring "\n *** Block name:\n")) ;;; (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1) (cons 2 bname)))) ;; All blocks by name: ;;; (setq bname (getstring "\n *** Block name:\n")) ;;; (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 66 1) (cons 2 bname)))) (setq axss (vla-get-activeselectionset adoc)) (setq com_data nil) ;for debug only (vlax-for a axss (setq tmp_get (get-all-atts a)) (setq tmp_data (append (list (vla-get-name a)(vla-get-handle a)) tmp_get)) (setq com_data (cons tmp_data com_data)) (setq tmp_data nil) ) ;ok (setq tot (length com_data)) (setq exc_data nil) ;for debug only (while com_data (setq tmp_snip (subtrack (caar com_data) com_data) ) (setq str1 (strcat "Subtotal blocks " "\"" (caar com_data) "\"" ": " ) str2 (itoa (length tmp_snip)) ) (setq exc_data (append exc_data (list (append tmp_snip (list (list str2 str1)))) ) com_data (vl-remove-if (function not) (mapcar (function (lambda (x) (if (not (member x tmp_snip)) x ) ) ) com_data ) ) tmp_snip nil ) ) (setq exc_data (mapcar (function (lambda (x) (mapcar (function (lambda (y) (append (list (cadr y)(car y))(cddr y)))) x ) ) ) exc_data) ) ;; Eof calc part ;; ;; *** Excel part *** ;; (setq fn (vl-filename-base (getvar "dwgname"))) (setq fname (strcat (getvar "dwgprefix") fn ".xls")) (setq fx (open fname "W")) (close fx) ;;; Excel part written by ALEJANDRO LEGUIZAMON - [url]http://arquingen.tripod.com.co[/url] (setq aexc (vlax-get-or-create-object "Excel.Application") awb (vlax-get-property aexc "Workbooks") nwb (vlax-invoke-method awb "Open" fname) sht (vlax-get-property nwb "Sheets") csht (vlax-get-property sht "Item" 1) cll (vlax-get-property csht "Cells") ) (vlax-put-property csht 'Name "AttOut-AttIn") (vla-put-visible aexc :vlax-true) (setq row 1 colm 1 ) (setq header_list '("BLOCK NAME" "SECTION NO" "FAMILY" "DESCRIPTION" "PN" ) ) ;_ end of setq (repeat (length header_list) (vlax-put-property cll "Item" row colm (vl-princ-to-string (car header_list)) ) (setq colm (1+ colm) header_list (cdr header_list) ) ) (setq row 2 colm 1 ) (repeat (length exc_data) (setq data (reverse (cdr (reverse (car exc_data)))) subtot (last (car exc_data)) ) (repeat (length data) (setq info (cdr (car data))) (repeat (length info) (vlax-put-property cll "Item" row colm (if (< colm 2) (vl-princ-to-string (car info)) (vl-princ-to-string (cdar info))) ) (setq colm (1+ colm)) (setq info (cdr info)) ) (setq data (cdr data)) (setq row (1+ row) colm 1 ) ) (setq colm (1+ colm)) (vlax-put-property cll "Item" row colm ) (setq exc_data (cdr exc_data)) (setq row (1+ row) colm 1 ) ) (setq row (1+ row) colm 1 ) (setq colm (1+ colm)) (vlax-put-property cll "Item" row colm ) (setq fcol (vlax-get-property csht "Range" "A:Z")) (vlax-put-property fcol "NumberFormat" "@") ;;; Columns("A:A").Select ;;; Range("A394").Activate ;;; Selection.NumberFormat = "@" (vlax-invoke (vlax-get-property csht "Columns") "AutoFit") (vlax-release-object cll) (vlax-release-object fcol) (vlax-release-object csht) (vlax-release-object sht) (vlax-release-object nwb) (vlax-release-object awb) (vlax-release-object aexc) (setq aexc nil) (setvar "osmode" osm) (setvar "cmdecho" 1) (vla-clear axss) (vlax-release-object axss) (vla-regen adoc acactiveviewport) (vla-endundomark adoc) (gc) (gc) (alert "Save Excel manually") (princ) ) (princ "\n\t\t***\tStart command with ATOUT...\t***") (princ) If not, then please post here the block you are using to allow a deeper investigation of the code. Quote Link to comment Share on other sites More sharing options...
ml3428 Posted June 22, 2012 Author Share Posted June 22, 2012 Thank You!!! This is exactly what I was looking for. You have been a great help. I really appreciate all the work you have done!!! Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 22, 2012 Share Posted June 22, 2012 You are entirely welcome! Glad I was able to help you. Quote Link to comment Share on other sites More sharing options...
giacomellino Posted May 14, 2021 Share Posted May 14, 2021 Hi, I tried to download the code you made but it doesn't say it's not available. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 14, 2021 Share Posted May 14, 2021 Did you copy the code and then open Notepad and paste, then save. Quote Link to comment Share on other sites More sharing options...
