alinaoac Posted June 19, 2012 Posted June 19, 2012 Hi, Can anyone tell me how to rotate the an image in solidworks? I have attached one image i need it to stay basically upside down rather than layed down like it is. Do i need to change it from the sketch or is there anything which allows my image to be rotated? Thank you Quote
JD Mather Posted June 20, 2012 Posted June 20, 2012 Why do you need to rotate? Hold down mouse wheel and move mouse. If you are trying to change relative to coordinate system, why? It should be irrelevant. A part can be in any orientation in an assembly. More information on the true problem description is needed. Quote
