Hi
We use autocad lt 2012, when creating a drawing, the same component can be used more than once, is it possible to print a detail listing of all the components used in a single drawing in some sort of report format, or maybe export the listing to a program like MS excel....etc
Regards, AQ
It sounds like you are looking to obtain a list of all the blocks in your drawing. Is that correct?
I believe the command you are looking for is ATTEXT. You might want to first consult your Help files.
This comes from the LT is Still AutoCAD website.
Need to count the blocks in your AutoCAD Drawing? Use FILTER or QSELECT commands. In LT2011 and LT2012 right-click and pick SELECTSIMILAR.
Edited by ReMark
