Hekainu Posted June 13, 2012 Share Posted June 13, 2012 Hi, I'm fairly new to AutoCad and I am trying to export a plan from Corel Draw X4 into AutoCad 2007. I export the Corel as a DWG which successfully opens in AutoCad. The only problem is that all the line weights and line styles from Corel have gone. Is there a way to do this which keeps the line styles or would I be better off exporting the various parts of the drawing as individual DWG files for reassembly in AutoCad? Thanks in advance! Amir Quote Link to comment Share on other sites More sharing options...
fuccaro Posted June 15, 2012 Share Posted June 15, 2012 I used to do similar jobs in the past, while in Corel 11. Exporting as DXF I remember I had the option to preserve the lineweight and color. It is possible to export the geometry as you suggested, using the "selected only" option. Open each drawing, put everithing on a named layer and finally bring all the drawings in one drawing where you can manipulate the layers properties. Quote Link to comment Share on other sites More sharing options...
