Benjo Posted June 11, 2012 Share Posted June 11, 2012 is there a command to redefine/update mulitple wblock? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 11, 2012 Share Posted June 11, 2012 There is a block replacement command in Express Tools that will replace one block with another. It's a start. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 11, 2012 Share Posted June 11, 2012 What do you mean by WBLOCK? WBLOCK just writes objects or blocks in a drawing to a new drawing file (.dwg). If it is a BLOCK you wish to update, plenty of LISPs around including the Express Tool>Blockreplace as mentioned by ReMark. Quote Link to comment Share on other sites More sharing options...
Benjo Posted June 11, 2012 Author Share Posted June 11, 2012 We use wblocks in ours drawing the problem is when you modify some wblocks, they dont automatilly update/redefine in the drawing they were insert before. so the only way i find to update/redefine these wblock, is to insert all of them again, one by one and redefine them. is there a command,lisp, something to do this faster Quote Link to comment Share on other sites More sharing options...
rkent Posted June 11, 2012 Share Posted June 11, 2012 We use wblocks in ours drawingthe problem is when you modify some wblocks, they dont automatilly update/redefine in the drawing they were insert before. so the only way i find to update/redefine these wblock, is to insert all of them again, one by one and redefine them. is there a command,lisp, something to do this faster If this is happening often I would consider xrefing in the various files. You are inserting .dwg files, they may have been made with the wblock command but that command creates .dwg files. Quote Link to comment Share on other sites More sharing options...
Alexandru Posted June 11, 2012 Share Posted June 11, 2012 autocad-expert.com/insert/block-definition/write-block/ Quote Link to comment Share on other sites More sharing options...
