User2012 Posted June 9, 2012 Posted June 9, 2012 I don't know what I am doing wrong in the process of Importing a CAD file in Inventor! In other words, some parts of my CAD features couldn't be appeared on .ipt view and also all commands of 3D Model tab didn't show up either! Quote
JD Mather Posted June 9, 2012 Posted June 9, 2012 Check the button for Wires to 3D sketch. Attach your original dwg here. Recreate in Inventor anyhow, this should take all of 2 minutes. Quote
User2012 Posted June 9, 2012 Author Posted June 9, 2012 Although I checked the button for "Wires to 3D sketch", I came with the same results! Here is the dwg file attached. Thanx! PS- I used CAD 2012 and Inventor Professional 2013 by the way. Bearing Cap.dwgFetching info... Quote
JD Mather Posted June 10, 2012 Posted June 10, 2012 Uhmm, you never Unioned the solids in AutoCAD. Either Union in AutoCAD or set to import multiple solids in Inventor. Quote
