RobDraw Posted June 8, 2012 Posted June 8, 2012 OK so how do i change the font. I have text that has been drawn on a text style, but the text itself has had its font individually changed, so no matter how many times I change the style, the font still needs changing. This is similar to having a layer which is coloured blue, yet all objects on that layer changed to yellow, no matter how many times i change its layer, everything will remain yellow until i change it to back by layer. Quick properties isn't the window i'm looking for. AFAIK, the font of single line text is controlled by the style only and cannot be overwritten. Even if MText that has had the font changed within the editor is exploded the font reverts back to the one defined in the style. If changing the style in quick properties or the full properties box doesn't work, make sure your styles are set up with the font that you are looking for. Quote
Dadgad Posted June 10, 2012 Posted June 10, 2012 AFAIK, the font of single line text is controlled by the style only and cannot be overwritten. Even if MText that has had the font changed within the editor is exploded the font reverts back to the one defined in the style. If changing the style in quick properties or the full properties box doesn't work, make sure your styles are set up with the font that you are looking for. A classic case of seeing a problem for what it is, and bypassing the obfuscation of cad jargon. I trust that your clarity has rendered the rest of our posts inconsequential. I really don't understand why anybody would choose to use TEXT over MTEXT, no doubt there are good reasons that evade me. Quote
