I have a variable say named pnt, but it can be either a 2d, 3d list or a visual lisp variant object, the question is how do you recognize this?
and when you did how do you get distance of two point objects? I mean what is the (distance) function to use with (vlax-3d-point)?
(cond
((eq (type pnt) 'Variant)(princ "\nVariant:"))
      ((listp pnt)(princ "\nPoint List")))
its either you convert the vairant value to point list (vlax-safearray->list (variant-value pnt))
or convert the point list to variant (vlax-3d-point pnt)
(setq p '(0. 0.))
(if (eq (type p) 'LIST)
 (princ (length p)))
(setq p1 (vlax-3d-point '(0. 0. 0.))
     p2 (vlax-3d-point '(5. 0. 0.))
(setq dist (distance (vlax-safearray->list (vlax-variant-value p1))
                    (vlax-safearray->list (vlax-variant-value p2))
