Geoffers Posted October 30, 2008 Posted October 30, 2008 ...trying to investigate annotative scaling- getting there I think. however I cannot understand the 'new' tile that has appeared between the scale dropdown and the annotation visibility tiles. The bar shows 10 named items but there are now 11 visible. It is split diagonally - top left, sort of 'model space' symbol; bottom right, scale triangle symbol. Any explanation please?? Quote
Geoffers Posted November 1, 2008 Author Posted November 1, 2008 is this 'ghosting', presumably of the annotative scales in use, normal? Quote
Geoffers Posted November 21, 2008 Author Posted November 21, 2008 ...investigated annotative a bit more... ghosting is the 'other scale' version of the text... but you know that didn't you. Also I assumed the other scale text was in the same position relative to the drawing geometry.. but not so, you can move it around...as in so many areas of Autocad still learning... Quote
