pleasehelp Posted May 29, 2012 Share Posted May 29, 2012 Hi All, I need to design a 'stencil' of sorts - but it just needs to be an array of circles separated by a constant distance. its an array of 200 micron diameter circles separated by a distance of 500 microns each (between centers). Its super easy to make this array, but when I try to 'pull' it into the third dimension, or extrude the array, I get an 'invalid' error. Or the highlighted objects just get 'unhighlighted' (for the lack of a better word) once i hit enter after selecting them all. Also, I made the entire array into a 'block' of easiness. Any help is hugely appreciated! Thank you! Mukul Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 29, 2012 Share Posted May 29, 2012 Go the other way maybe make 1 extrude then array. Quote Link to comment Share on other sites More sharing options...
