kingkp123 Posted May 26, 2012 Posted May 26, 2012 i have lofted two different triangles made by using line. they lofted fine but it is see through, how do i make it opaque? i use inventor 2013 Quote
JD Mather Posted May 26, 2012 Posted May 26, 2012 It doesn't sound like your sketches are constrained (edit sketch and look in lower right corner of the screen - what does it say?), you have a surface body (look in the browser - is there a surface body folder?). Attach your file here. Quote
kingkp123 Posted June 11, 2012 Author Posted June 11, 2012 here is what i have... i dont understand what you mean by surface body Part1.dwg Quote
JD Mather Posted June 11, 2012 Posted June 11, 2012 I see an extruded rectangle not two triangles. I see a dwg (AutoCAD) not an ipt (Inventor) file. How much training have you had? Are you sure you are using Inventor? Quote
kingkp123 Posted June 11, 2012 Author Posted June 11, 2012 never mind i figured out my problem thanks! Quote
