Does anyone know or can help in a routine that allows you to create a new dwg file from a selection?
I know I can do in other ways, for example, isolating the selection and making a save as, or copy/paste into another session, but to do this in several selections becomes impractical.
Thank you for your help.:)
This can be achieved easily with built-in WBLOCK command.
It's true. I was forgetting this possibility. :oops:Thank you for remembering.
You’re welcome!
But, I just noticed that there was a previous, identical response, so the thanks should go to Stefan!
