GoldenFoxSilverHare Posted May 21, 2012 Posted May 21, 2012 Hi I have been an AutoCAD user for years but I am recently running into the issue of working with certain users that are still scaling their drawings in model space and I cannot for the life of me figure out how to scale it back to 1:1 so that I can draw in it! Most of the drawings I come across are drawn to 1/8" scale, and I only know this because they are drawn with scales in model space to reference. The drawings are set up at 1/8" and when I dimension, it dimensions correctly but when I draw it is 1:1 and so my lines are massive in comparison. I have read all the forums and tried numerous attacks with the 'scale' command to no avail. I am extremely frustrated as this brings my work to a stand still. Please help! Quote
GoldenFoxSilverHare Posted May 21, 2012 Author Posted May 21, 2012 I know i posted in beginners and I expect the answer to be extremely easy (even though I've yet to figure it out) but please be nice. The answer is, Yes, I know these factors but I am not computing how to apply them correctly. What Command? What options? Unfortunately it will hit me like a ton of bricks when someone tells me exactly how, but that's what I am asking for here... please someone give me a step by step. Quote
ReMark Posted May 21, 2012 Posted May 21, 2012 Try using the Scale command. If someone scaled the drawings up by a factor of 96 then you would have to scale them down by the reciprocal of 96 (1/96). Quote
bill_borec Posted May 21, 2012 Posted May 21, 2012 One trick I have picked up is to measure a correctly dimensioned object/line/length/etc...then select all and scale to "correct dimension/measured"... so, if someone drew a table and the top was supposed to be 10-feet by 4-feet and the drawing was done at 5x2...simply select all and scale at "10/5"...that will make the object scaled to the desired measurement. Hope this was clear! Quote
nestly Posted May 22, 2012 Posted May 22, 2012 Use the [R]eference option of the SCALE command if you know the real size of any of the objects in the drawing. Quote
Dadgad Posted May 22, 2012 Posted May 22, 2012 Welcome to the forum. Having not seen a confirmation that it worked out for you, and that you are back in the game, I am curious if your problem has been resolved? Standing by to help, if still needed. Quote
GoldenFoxSilverHare Posted May 22, 2012 Author Posted May 22, 2012 I win! Thank you all for responding so quickly and special thanks to bill_borrec for the tip on the reference portion of the scale command. I utilized a standard doorway to bring the drawing up to scale; after a few tries I figured out the right combination of clicks and inputting 3'-0" to find the solution. 1. Select all 2. Scale command 3. Select a base point 4. Reference 5. Select two points 6. Enter what the correct measurement should be between those two points Quote
